Ga door naar hoofdinhoud
Does anyone know how to disassemble a Jabra Evolve 80?
Hi,
So, as expected a couple of weeks after warranty my headset isn't working.
The left speaker isn't working.
I've noticed that for other Jabra headsets there's instructions on what the problem probably is (loose connectots etc).
BUT, I can't for the life of me workout how to disassemble to even have a look.
The best I can do is remove the cushion.
Has anyone done this or have any info how-to?
Cheers,
Is dit een goede vraag?
Score 2
1 Opmerking
hello @caidom
I have a broken headrest on the exact same pair i have been looking for a few hours for a part with no luck. would be happy to exchange info on how to open these headphones for a link or few to a replacement headrest. thanks <James>
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi @caidom ,
Have you verified that the problem is in the actual headphones and not in the cable or plug?
Plug the headset into an audio output source, firmly hold the plug into the socket of the audio device and then gently move the cable where it exits the plug, back and forth and listen if the sound comes and goes in the left earphone. (only "wear' the left earphone to make it easier to discern if it is there or not).
If you still cannot hear anything try the same thing where the cable enters the headphones. Gently move the cable back and forth and listen if the sound comes and goes.
A lot of times the cable fractures (internally) where it exits the plug because people generally unplug the headphones by pulling on the cable and not the plug.
Also if the problem appears to be at the plug end it may be that the plug connection for the left speaker is loose or faulty. The left speaker is connected to the tip connector in the plug.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Hi @jayeff ,
Thanks for the answer, but this "isn't" my first rodeo.
It's definitely the connection inside the ear piece.
If you have any idea how to crack the Evolve 80 open, that'd be great :)
Cheers,
door
Hi Daniel,
I have Evolve 80 , and know how to dissasemble.
First rotate ear cushion 45 degrees counter clock wise, then it comes off.
On the surface under the ear cushion , there is a black square - this is a piece of thick tape you can take off with a scalpel / knife. a phillips screw is visible.
I believe after this you can do the rest yourself.
Feel free to contact me if more help is needed,
Update (10/22/2019)
I created a small guide on this headset on ifixit.
Score 3
3 opmerkingen:
Hi, can you send me the guide for fixit to my email smatiz @ hotmail . com, i have a problem with the microphone
door
Did you get this fixed? My mic just stopped working. Thanks
door
I just fixed my mic. Open that screw on the picture, then there is lot of screws that needs to be opened. And after that the metal look like a ring outside can be removed and you can see the mic wire. It seems that it will eventually get broken if you move this mic up and down many times. So better to keep it one position most of the time.
door
Voeg je antwoord toe
Daniel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 12
Altijd: 3,160
