My 40 inch Vizio model D40u-D1 keeps turning off and restarting.
When I turn on the tv if comes on and shows a picture for about 2 seconds and turns off and then turns back on automatically again until picture shows for about 2 seconds. Then it turns off again. It continues this cycle for several minutes and then it finally comes on and stays on. I have changed power cord, tried different outlet, unplugged power and pushed and held power button on the back for 30 seconds. It still does it. What to do to fix?
Is dit een goede vraag?
2 opmerkingen
Hello Thomas,
I have been having the same problem with my TV for a while now. If you find a fix somewhere, I would appreciate it if you shared. My problem happens with several devices. Doesn't matter what HDMI Cable I use. It's very annoying.
door Luis Bermudez
I have a 70in vizio about 5 years old that keeps shutting off as soon as the picture loads. I've tried unplugging the usb ports and tried holding the off button down to no avail. Also tried a hard disconnect did not not work either unfortunately… can anyone help with this situation?
door jakemckamy
