Ga door naar hoofdinhoud
This is the device page for the Samsung Galaxy J7. The OS that comes stock to the device is Android OS v5.1.
170 Vragen Bekijk alle
My j7 max lcd has been broken can I purchase on max screen to replace
J7 max lcd is too costly can i purchase on max screen which is of same size and has same feature
Is dit een goede vraag?
Score 2
1 Opmerking
My J7 max display was broken so i changed with new one and it's working for 2days after that it's turned off what wasthe problem
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hi @sunnyp,
Normally No.
Not unless you were absolutely sure that the individual wire functions of the cable connected to the new screen exactly matched the wire functions of the screen that you wanted to replace. If they are not identical as to wire functions it will not work
It is very difficult to find out what each individual wire does.
Not every LCD screen is cabled the same, even though they may be of the same size etc
Was dit antwoord nuttig?
Score 6
Samsung j7 Max display not working
Voeg je antwoord toe
Sunny prasad zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 15
Altijd: 1,386
