Ga door naar hoofdinhoud
Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
782 Vragen Bekijk alle
The LCD is "jumping" up and down + horizontal lines
The LCD on the MacBook Pro early 2011, 13" is "jumping" up and down and at certain display positions horizontal lines are running up and down the screen and the screen gets frozen.
And often it is only the half lower part of the LCD which is "jumping" up and down. The lines though are on the whole LCD.
At certain display positions it can work normally sometimes.
What can the problem be, can it be a display cable which is faulty? I don't think the actual LCD display is faulty since it works in certain positions.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I would examine the LDVS cable as picture in step # 14 of this guide. Reseat it it and examine for any corrosion. MacBook Pro 13" Unibody begin 2011 Vervanging van het scherm
Was dit antwoord nuttig?
Score 2
Bad LVDS cable most likely. Could be the LCD or connector on the board but I would highly lean on a bad cable
Score 2
1 Opmerking:
I checked that cable on the motherboard side, all looks good and nothing happens when i move around the cable at that end.
But maybe the problem is at the LCD end of that cable?
Can i access that connector without removing the whole display unit from the rest of the computer? Can it be accessed by only removing the glass and then removing the screws for the LCD and then just move the LCD?
door
Voeg je antwoord toe
Jon Smith zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 668
