Ga door naar hoofdinhoud
Model A1297 Unibody: Early 2009, Mid 2009, Mid 2010, Early 2011 & Late 2011
544 Vragen Bekijk alle
Is it NOW safe to install/upgrade to High Sierra from Sierra?
Hello iFixit experts,
I had some (or rather a lot of) trouble with HS on my MBP Early 2011 for which I had posted a couple of questions and thanks to iFixit experts was able to get things sorted out and bring the MBP back to life, albeit on Sierra. So my question was:
With HS v.10.13.2, is it now safe/feasible to upgrade to HS and not have all the APFS/SSD/HDD errors that have been raging on various forums.
Side note: I upgraded the HW on the MBP to 1TB Western Digital SSD (no TRIM) and 16GB 1600Mhz Crucial RAM. Original HDD is intermittently used as external if required.
Thanks for you time.
Is dit een goede vraag?
2 opmerkingen
Is this question on a different machine that what you discussed before? Is it the 17" early 2009?
door
This is the same machine as before early 2011 actually
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Sorry No
Apple has not fixed APFS yet in High Sierra. Stick with Sierra if you have a SATA based SSD drive!
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Thanks. When can we expect the fix for SATA SSD drives to come, i.e. probable version #? Because I think in the recent one they were probably focused on the root administration security flaw fix.
door
I don't work for Apple ;-} So your guess is good as mine. I'm sure Apple will let us know.
door
Voeg je antwoord toe
Ravi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 463
