Why does my wireless headphones not play any sound?
Okay, so I got these Skullcandy Uproar Wireless headphones in August, it's now December and they aren't working right.
They pair with my phone and charge correctly. They turn on and connect smoothly but when I go to play music, they will start to play but then there will be no sound and the song will continue to play as if they are still connected. Sometimes there will be a glitching sound or white noise before the audio stops.
They stay paired and on, like normal but no sound. I checked to see if they were connected to media and phone and they are, but I can't figure out the problem. Even turning the volume up and down it says it's connected. They seem to work great, just no audio and the crackling noise. I don't pair any other devices to my phone so it's not Bluetooth signal. Even after I turn them back on they will work at first but then stop. I can't even get through one song and it's annoying.
Is dit een goede vraag?
6 opmerkingen
My skullcandy wireless don't have any more volume I turn it all the way up but still sounds very low. Can any body help me or is there a way to put more volume.
door jsoulder80
I have the same issue. Headphone just randomly stop playing any sound but it’s still connected and playing on the device. This happened on multiple devices and multiple apps. So this should be an issue with the headphone. I had to re-paired to fix but issue keeps coming back. Any other solution?
door Baltax
Mine is a similar issue although there is no voice when I connect to my phone…. However if I connect to my laptop the earphones are working
door trishalanair2411
If your headphone is not working properly when connected to other devices, it is likely that your headphone is broken.
door DesertKiwi
I'm from Suriname and I experience the same issue with my headphone.. Sadly, I thought this beats Jbl headphones. Earlier, I could connect it with any device, but as soon as my partner connected his Iphone with it, it won't play music on other devices. Anyhow, I enjoyed it nevertheless and will replace any sooner
door esilsah.kartijoatmo
1 commentaar meer tonen
