Ga door naar hoofdinhoud
The Panasonic Lumix ZS50 (Northern America) or TZ70, Tz71 is a small, lightweight personal travel camera, released in March 2015. The camera features a long lens from Leica (30x zoom, 24-720mm), heightened low-light sensitivity, built-in viewfinder, and a 12.1 megapixel resolution.
When I zoom in a little, the view becomes blurred.
At first, the view is in focus. After I begin zooming in very much (yes, I can hear the motor) the photo view becomes blurry. (I see 1.6 across the screen) If I try zooming back out all the way, the photo view stays blurry; however, if I turn off the camera and on again, the photo view again is clear until I try zooming in very much I have reset to factory and that did not change the problem. Yes, I am a novice.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
If your camera is on AF-S, half-press the shutter button to refocus. If it is in AF-C, it should focus automatically, but always half-press the shutter button before taking the picture to be sure the picture is in focus. Be sure pre-focus is on if your camera has that setting.
Here is the manual if you need any help:
ftp://ftp.panasonic.com/camera/om/dmc-zs...
Hope this helps!
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Sara Thomas zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 15
Altijd: 1,598
