Ga door naar hoofdinhoud
The fifth-generation Elantra debuted at the 2010 Busan International Motor Show in April 2010. The fifth-generation Elantra (2010-2015) added a two-door coupe variant in addition to the standard four-door sedan model. These Elantra vehicles included six-speed automatic or manual transmissions.
Where is the camshaft positioning sensor located 1.8L
hi, can someone let me know where this is? 2011 Elantra 1.8L
thank you
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
It is in the front of the engine, down low, just to the right (as you are facing the car from the front) of the oil filter.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
This is erroneous! This is the location for the crank sensor.
door
No it's not that the crank sensor can sensor is on top of motor.
door
@rnps old question and just to clarify. The camshaft position sensor is (are since we do not know if this is a 1.8L DOHC engine which would have two) located under a cover on the TOP right of the engine.
image credit goes here
Hopefully you got this fixed within the last 4 years :-)
Score 1
این سنسور روی سر سیلندر سمت چپ خودرو و در انتهای میل سوپاپ قرار گرفته
Voeg je antwoord toe
Robin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 33
Afgelopen 30 dagen: 155
Altijd: 6,644
