Why is my unit wont start with the battery inserted and causes trouble
why is that my unit wont start with the battery inserted on it and causes trouble on its keyboard? The key wont function.
Is dit een goede vraag?
arvin.sevilleno double check your battery and see if it is swollen. This may prevent your keyboard from working. If your keyboard works with the battery removed, then the issue will most likely be resolved by replacing the battery.
Was dit antwoord nuttig?
@oldturkey03 even if I try to used the ac adaptor direct to the unit still the keyboard is not working. . .thank you for your recommendation. . .this helps a lot. . .
arvin.sevilleno you must physically remove the battery. If your keyboard works then, it's your battery.
@oldturkey03 yes sir I physically remove the battery and still the keyboard is not working. . .thank you.
@oldturkey03 I try to turn on the unit with out the battery and still the keyboard is not working. . .when the battery is inserted and when i try to turn on the unit it is not turning on. . .thank you.
arvin.sevilleno in that case you most likely will have to replace the keyboard.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 10
Altijd: 127
