apple hi-fi won't work on mains, it only works on batteries.
Hi, my apple hi-fi won't work on mains supply, it only works on batteries. help
Is dit een goede vraag?
Hi @iain_sinclair ,
You will have to open the device and then check the connections from the mains power inlet to the motherboard.
Here is a link that hopefully may be of some help.
If you cannot see (or test, using a DMM- digital multimeter) what the problem is, take some close up pictures of the motherboard and perhaps someone will be able to help you further. Here's how to do that. Voeg afbeeldingen toe aan een bestaande vraag
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 250
7 opmerkingen
Please explain. Do you mean it won't work on wall power?
door Reed Crosby
yes, thats correct it won't work on wall power
door Iain Sinclair
Have you tried a different outlet?
door Aiden
yes tried different wall outlets and different power lead, the problem is with the apple unit.
door Iain Sinclair
did you drop it before? anything happen before it broke?
door Aiden
2 commentaren meer tonen
