Ga door naar hoofdinhoud
Reparatiehandleidingen, demontage- en probleemoplossingsinformatie voor de 5e generatie Apple iPad met Wi-Fi, verkrijgbaar met 32 of 128 GB opslagruimte. Uitgebracht in maart 2017. Te herkennen aan modelnummer A1822. Voorzien van een 9,7" Retina-display en 64-bit A9-processor.
Replaced Screen - Home Button Works But Not To Wake?
Hi All,
Just replaced a digitizer on an iPad 5 (2017 model). All went fine, was very careful.
Home Button assembly hasn't been damaged ..... but now the home button will not wake the iPad from sleep?
If I wake up the iPad from sleep using the power button, the home button works 100% , as both a button and the Touch ID - 100% functionality.
Any ideas why it won't work to wake the iPad up though?
Thanks
Alex
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Filteren op:
Het nuttigste antwoord
My thoughts point towards the magnet sensor that senses a magnet inside a case, telling the iPad to wake up if you uncover the screen. I never checked the schematics for that but considering the symptoms of your issue i guess they share the same circuit.
This sensor is soldered on and should be removed and replaced to the new assembly with a heat gun or something like that.
Was dit antwoord nuttig?
Score 1
3 opmerkingen:
Thanks for that, have you got any info as to the location of this sensor? I had a quick look and there doesn't seem to be anything obviously different between the new and old assemblies?
Already moved the entire home button assembly / bracket / ribbon etc.
door
Could be one similar to this: https://www.dropbox.com/s/gi7vmhfwvu9wtd...
This is on an Air2, so not sure. It is covered by some black tape
door
Thanks for that, upon further inspection the home button doesn't appear to be working as a button AT ALL!?!?!?!
It does still physically "click" and Touch ID works 100% - just not the button function?
door
Voeg je antwoord toe
Alex S zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 14
Altijd: 1,080
