Ga door naar hoofdinhoud
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
Searching/ no service problem (read)
I recently purchased an se from an owner who’s screen was smashed. I fixed the screen (full replace) everything works as it should except searching when I boot the phone and no service if I try to remove the sim.
I’m a majorly expirienced tech so don’t go : pull the sim in and out update carrier settings etc.
I’m thinking it could be one of the ic’S or the antenna. Non of the symptoms for a bad ic appear. I can see the imei modem etc all numbers come up except for the actual network. Field test also doesn’t work.
My thinking is that maybe one of the antenna grounds is loose or something.
How can I test the hardware , I cannot see any problems , I did an Apple diagnostic with Apple and they said the hardware is functioning correctly.
I don’t want to randomly swap ic so if someone could help narrow this down I’d love you forever. Maybe even blow you but you’ll have to take me to dinner first. I’m classy.
Ps no water damage.
Is dit een goede vraag?
Score 1
2 opmerkingen:
did you try turning airplane mode on and off
door
Yes all things like this have been tried.
door
Voeg een opmerking toe
2 Antwoorden
Have you tried with a different SIM card? What carrier are you using? I have the same iPhone SE 64GB and I’m on Verizon. Have you tried replacing the ic’s?
Was dit antwoord nuttig?
reball & change ic baseband
Voeg je antwoord toe
petey Wheaty zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 983
