Ga door naar hoofdinhoud
Launched in 2012, the Asus X54C features an Intel Pentium Intel® Core™ i3 Processor, Intel® Pentium® Dual-Core Processor and Intel® Celeron® Dual-Core Processor
17 Vragen Bekijk alle
My Asus X54H, wont power on. Power supply is working good.
My Asus X54H wont power on. Power supply is good as i used it on other laptop and its working. When i power it on, only 2 led lights remain on; 1 green led and 1 red led. pls help
Is dit een goede vraag?
4 opmerkingen
Which lights are on? and which colors are on with each light?
door
@fcaancan If you figured it out please say what you did so other people can fix their issue if they come across one like yours. Thanks!
door
I havent figured it out. The power indicator light switches on (green led) & the battery indicator light is also on (orange led). But the OS LED light does not turn on. A friend told me my HDD could be damaged and suggested to replace it.
door
Hi @fcaancan, is there any display output on your computer screen? If so, try follow ayeff advice to check on the HDD first :)
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi @fcaancan
Get into BIOS on power up to check if the HDD is being detected. If not check that the HDD connection is OK
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Fred caancan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 12
Altijd: 747
