Help Touch Not responding.
Question.
I have been new to working on cell phones. I recently took the glass of 4 s6 edge and the foil that goes under the glass with no issues touch works digitizer works everything worked perfect.
Now I stated doing s6 edge plus I manged to do exactly the same process the lcd works properly no issues but the touch is not responsive, I have failed on 2 devices already. One i took off the glass and before cleaning the left over loca glue i tried to play with it but the touch only responded to half 3/4 of the screen. I left it alone i tried another one and the exact same issue.
Keep in mind i haven't cleaned the left over glue which on the s6 edge regular it was no problem even with the left over glue on it the touch responded likea charm.
Any suggestions of why you all think the touch is working on the regular edge but not on the plus??
Thanks in advance
Is dit een goede vraag?
Voeg een opmerking toe
