Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2690 Vragen Bekijk alle
I phone 6s motherboard replacement with a new block iPhone 6
Hi everyone , I am currently using a iPhone 6 s . Recently having problem with its touchscreen , the lower bar of the screen is compleatly not working , and battery is down , show charging sign but doesn't change the percentage number with keep restarting .
On the other hand I have another iPhone 6 with network block so I can't use it .
To not that my faulty iPhone is 16 gb but the other one is 64 .
So is there any solution that I can change the motherboard of my block iPhone from my old one and use it ?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Hi if you manage to do this you are a magician.. forget about this.
It would be easier to fix the original iphone 6s, test a new screen and battery would be a good start
Was dit antwoord nuttig?
The components are not compatible between those models. I recommend a new screen and battery as first steps.
Voeg je antwoord toe
Arif zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 1,189
