Ga door naar hoofdinhoud
Sony Xperia Z3 Dual also known as Sony Xperia Z3 D6633 is announced in September, 2014. It features 146 x 72 x 7.3 mm (5.75 x 2.83 x 0.29 in) body, IP68 certified, 5.2 inch display and 20.7Mp rear camera.
27 Vragen Bekijk alle
My phone not charging on wall socket but can charge on my pc
my phone is not charging on wall socket/charger but it is charging on my PC using data cable. i repaired software it started charging but time zone changed.when i use automatic time zone it goes 3hours infront. i repaired software again and it stoped charging on the socket again.kindly help
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Patrick Kimeu since it worked after you "repaired" the software it does not seem to be a hardware issue but software. you may want to try to reinstall your operating system or do a complete reset.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Patrick Kimeu zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 127
