Ga door naar hoofdinhoud
Shark Ultimate Professional 1800-watt strijkijzer, geïdentificeerd door modelnummer GI505.
Iron not powering on
My Iron is plugged in and is still not powering on or heating up, could the cord be broken?
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Have you tried a different plug? Or maybe the iron needs more water.
Was dit antwoord nuttig?
Score 3
Open it up using this guide and then use a multimeter to test it:
Shark Ultimate Professional Printplaat vervangen
Score 3
1 Opmerking:
Would you be willing to work on an iron?
door
This Happens sometime, If you forgot to switch off your iron it get over heated and may melt the wire of circuits of the iron.  I have gone through it, Do check your Wires properly. Also check the power wire fwether it get burned out or not.  You may need to replace whole wire.
In case you are planning to buy Get it here: - Best Steam Irons in market
Score 2
1 Opmerking:
If you know someone who would be willing to work on an iron, I would like to mail it to them and pay for the service. Thank you, Stephanie
door
Voeg je antwoord toe
Matt Brunswick zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 51
Altijd: 7,100
