Ga door naar hoofdinhoud
Vierde generatie iPhone. Reparaties zijn eenvoudig, maar het glas aan de voorkant en het lcd-scherm moeten als één geheel worden vervangen. GSM / 8, 16 of 32 GB capaciteit / Model A1332 / Zwart en Wit. Deze pagina is bedoeld om gebruikers te helpen bij het opsporen van problemen, het repareren van de iPhone 4 en het zoeken naar hulp.
Back panel will not slide back on?
I followed the guides within here to take apart my iPhone 4. And made sure to follow and remember every screw I took out, etc. My question is, whenever I go back to slide the back cover back on...it will not fully slide down into position for the two holes to screw it in place...it seems to be "stuck"... any ideas?
Is dit een goede vraag?
Score 3
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
you need to put a little bit of force, and check out the outter frame that it is aligned with the housing as u slide it on. :)
Was dit antwoord nuttig?
Score 5
3 opmerkingen:
Thankyou! Put a little more force on it, and bingo, "clicked" right into place no problem. Thanks! :)
door
Please "accept" an answer if it solved your problem so that it can be archived for others to learn from. Thanks
door
You guys helped me out too! I thought I was going to have to reassemple everything. Then I was scared to apply more pressure. Thanks Guys! Who needs apple care?! IFIXIT!
door
This has happened to me a lot and i have found that the reason being, for me at least, is that i forget to make sure the 6 side screws (with washers) aren't tighten all the way. After i retighten those it fits like a charm!
Score 1
I just broke the !@#$ out of hte back of my iphone doing htis
Voeg je antwoord toe
Ryan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 28
Altijd: 9,542
