Ga door naar hoofdinhoud
De nieuwste telefoon in de HTC One-lijn, simpelweg de HTC 10 genoemd, kwam uit in 2016.
Adhesive for the screen?
Which one is used in the video?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
Not exactly sure what Eric is using here but I find 3M two sided tape works well in this application
Hope this helps
Was dit antwoord nuttig?
Score 3
I just recently replaced battery and screen(after breaking screen during battery repair). I used double sided tape to hold the screen together. Anything on amazon would probably work, I prefer you get 1mm, 2mm, and 3mm width pack cause the 1-2mm works great for the side bezel while the 2-3mm works good for the top and bottom. Works great except for the lower part where the fingerprint scanner is. I can't get a precise measurement but it seems like the tape is 0.25mm thick, as in the height. This was too thin for the lower part. It would separate and I would see the light bleed out the sides, so I had to double up the tape to get the bottom to stick.
Score 2
Voeg je antwoord toe
belokk zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 18
Altijd: 1,764
