Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Why cant my phone turn on
Had a replacement on my iphone 6 lcd today because my screen had ghost touch sometimes, but other than that my phone worked fine. The ghost touch annoys me a lot when it happens tho, so I figured a replacement was a right idea. I was pretty excited to get a to do a screen replacement on my own, and that's all over my head. but right after I dis attach the screen removing all the ribbon cables... I realized that I forget to turn off my phone. Had a bad feeling during the fix, and as I expected, the phone did not turn on after.
I looked for solutions, here is what I tried.
-holding home button and power button for 1 min
-plug charger in from wallplug, plug charger in to computer to see if it can connect to itune to enter dfu mode
- checking for battery
- replace it back to original screen,
-repeat whole process
this happened an hour ago and I am firm to tell you that all hardware in my phone worked fine, but doing all of this above gave no result intoto fixing my phone, I dont want to go into apple store because I think they give copy pasted solutions and expect us to give them money for them.
Please help me!
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Alright after a long ****ing time, my friends and I found out that I bought a defective home button on ebay , and it blocked the electricity going through the circuits causing my phone to not turn on. I removed the home button and replaced it with a new one and my phone turned on! remember to check if your phone have any defective parts or else your phone is not going to work properly.
Was dit antwoord nuttig?
Het nuttigste antwoord
In the past I have reset the battery lead and then have success. Did you also see what voltage the battery is at? Jumping it with a power supply at 4.2V works for me all the time as well.
Score 1
4 opmerkingen:
mines is at 3.82v, but just a question would you think that I had damaged the logic board by not powering phone off when disattaching and as a result cant open my phone?
door
I mean ESD is a thing too, but I have never experienced that my self.. Hmm maybe try resetting the ribbons a couple times for the screen that is always my go to
door
Alright after a long ****ing time, my friends and I found out that I bought a defective home button on ebay , and it blocked the electricity going throughthe circuits causing my phone to not turn on. I removed the home button and replaced it with a new one and my phone turned on! Thank you for the help anyways!
door
Oh %#*@! Well nice trouble shooting on that one haha. You okay with the touch ID not working? Glad you got it figured out.
door
Voeg je antwoord toe
ed lian zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 75
