Ga door naar hoofdinhoud
HP Part#: CN731A#B1H: Printer, scanner, copier, web browser with wireless internet capability
16 Vragen Bekijk alle
Why does my printer keep saying paper jam but non seen?
I have done everything possible( cleaned the rollers, reset the printer, checked to ensure that there isn’t any objects stuck in it) but it just keeps saying “ clear paper jam” every time I try to print something. I’m going cookoo
Is dit een goede vraag?
Score 4
1 Opmerking
How do I remove the paper feeder to get to the paper jam?
door
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Reset the printer. that worked for my HP 6968 printer. remove the power cord from the back of the printer while its still turned on & idle. i kept it unplugged for about a minute or two and the paper jammed error was gone. just to be sure i restarted my laptop and wifi too.
Was dit antwoord nuttig?
Score 2
Have you read this? https://support.hp.com/gb-en/document/c0...
Score 1
I just couldnt get the fake paper jam error resolved…went back to reset factory default which solved it.
2 opmerkingen:
How did you do the factory reset? I can't figure out how to fix this exact problem.
door
where is the Color Laser Jet Pro MFP M477fnw factory reset button
door
Voeg je antwoord toe
Areean zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 14
Afgelopen 30 dagen: 30
Altijd: 13,452
