Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S Plus that was released on September 25, 2015. Model A1687, A1634
1041 Vragen Bekijk alle
Says its charging but its not gaining percents
So I got an iPhone 6s plus, the water damage thing has gone off at the top..
I have tried a new battery x4 and charging ports x4...
it says that the phone is charging but the "26%" is just standing on 26%. I know its not the cables fault as I have used it on my own phone and its working..
Could this be a board issue that needs soldering or what?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
After battery and charging dock replacement i would say it's the tristar IC (1610A3), but because was liquid damaged a technician needs to look at it, make sure the board is properly cleaned and there a no other shorts or problems that can make the phone to not charge.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
I don't do board repairs that why, but the customer agreed, he only bought it for $30 hoping it was an easy fix.
door
Het nuttigste antwoord
when the phone is water damaged the logic board needs properly cleaned, you will need to take the board out and inspect it for corrosion. there could be corrosion under the metal shields so just looking at the parts around the shields wont help you will need to look under the shields aswell.
Score 2
1 Opmerking:
this wasn't helpful but it won't let me vote because I don't have enough reputation points
door
Voeg je antwoord toe
nicolay.94 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 5
Altijd: 12,363
