Ga door naar hoofdinhoud
Sluit je aan bij de reparatiegemeenschap! Maak een account aan
Een 16 GB Android-tablet met een 7,9-inch beeldscherm, geproduceerd in 2014 door Xiaomi.
What is this component?
Hello everyone.
I'm actually trying to replace my Mi Pad 2 screen + digitizer. When i tryed to unstick the broken screen + digitizer from the frame i made a damages on a component stick to the frame.
This photo is going to show you the front panel empty ( i left the broken screen + digitizer)
Afbeelding
I zommed on top left of this front frame where is the damaged component.
Afbeelding
on the back of the frame at the same place there it his other part of this component
Afbeelding
I'm supposed to plug the mother borad on this :
Afbeelding
Do you think this component is important? It's write on this : "0 w1 mp aac 160328"
Thanks for support =)
Is dit een goede vraag?
Voeg een opmerking toe
4 Antwoorden
Filteren op:
Gekozen oplossing
Hello mates,
Thanks you so much for react fast like this.
When you said "radio" do you mean FM Radio, same radio that every one can have in his car?
Because the wifi is a radio sgnal (in other frequency).
Will only the FM radio be impacted or all orther radio signals like wifi and bluetooth?
Thanks you again ;)
Was dit antwoord nuttig?
2 opmerkingen:
probably all signals, but the damage is so minor that the effects will be negligible. So you have nothing to worry about.
door Deel
WiFi and Bluetooth. Because those two usually use foil antenna under the glass or rear case, while FM radio uses your headphone wire as the antenna. Also I’m bot sure if your device has FM radio to begin with.
door Deel
Het nuttigste antwoord
Antenna, you may degrade or destroy radio performance if you damage that part.
Score 1
Tom chai is correct on what is. As for importance, it should still function perfectly fine with the damage, but as Tom said, it wont be as good as it used to be but it should be perfectly fine for what your using it for.
Score 1
Thanks for the info,
i was wondering informations before order a new screen kit ( about 50$ ).
Thanks you so much. I still use an old 2012 galaxy s3 4g that run perfectly android 6.0.
Smartphones hardware upgrades is bullshit most part of time.
see you my friends.
Voeg je antwoord toe
Matteo GACHON zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 17
Altijd: 520
