Ga door naar hoofdinhoud
Battery operated RC truck designed for rock crawling and off-road terrain. Made by Maisto Tech.
17 Vragen Bekijk alle
Can the truck be tested or powered on without a remote?
We bought a used truck at a thrift store, and it didn't include a remote. Before we invest in a replacement of the remote, we'd like to test the actual truck to make sure it works. Is there any way to test the vehicle without a remote, such as turn on the motor?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi!
Yeah, you could theoretically wire up some batteries to the motor if you can access the main circuit board and see in it does anything. While I don't own this this thing personally and never tried this, I don't see what could go wrong. Just be sure to wire the batteries/ power source up properly and avoid applying too much power.
PS: This will also be helpful.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
EJ M zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 18
Altijd: 167
