Ga door naar hoofdinhoud
GSM iPad 2 with 16, 32, or 64 GB of storage, and a Dual Core A5 Processor. Model Number A1396. Repair is complicated and requires heat and prying.
152 Vragen Bekijk alle
Digitizer won’t respond to touch after being replaced
I repaired an iPad 2 by replacing a digitizer before peeling back the adhesive strips I tested it. The new digitizer it will not respond to touch. I made sure all of my ribbon cables were connected properly and it still won’t respond to touch.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Chances are the digitiser is faulty if you tried testing it before installation. As you said you have fully plugged in the digitizer ribbon cable.
Was dit antwoord nuttig?
Score 2
1 Opmerking:
Thank you for your advice. I have solved my problem. I really appreciate your advice in solving my problem.
door
Voeg je antwoord toe
Pbearbear zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 50
