Ga door naar hoofdinhoud
Repair guides and support for Saturn's 2nd generation SC, SL, and SW.
19 Vragen Bekijk alle
Manuel transmission 1999 Saturn sl, replace
5 speed Manuel trans replacement
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
William Emerson excellent write up about the how-to on here. Definitely not an easy job. I would also recommend that if you need more information on this extensive task, visit your local library and see if they have the manual.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
Thank you for your help, I have a 1999 3 door Saturn 5speed Manuel trans, mine is broken looking for another one
door
William Emerson not sure where you are located. I would connect with a local recycler. I guess that's what they call the wrecking yards now. Even if they do not have it they can probably find one for you.
door
Voeg je antwoord toe
William Emerson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 59
