Ga door naar hoofdinhoud
Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
220 Vragen Bekijk alle
Strip of digitizer unresponsive
I replaced the digitizer on my iPad mini 2 but I’m having a problem. There is a strip, approximately 1” across the top, that is not responding to touch. The screen is fine and everything else is working but nothing happens when I touch within this strip. Is there a problem with the digitizer or did I do something wrong?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Most likely it is a faulty digitizer (probably a weak solder joint on the flex). I would try re-seating the digitizer connector to the motherboard, just to make sure it's not loose. If you still have issues, get a replacement digitizer.
If a replacement digitizer has the same problem, you should look at the digitizer socket on the board.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thank you!
I just re-seated the digitizer and checked the pins so see if anything looked bad but they seemed to look fine. Now less of the screen works and it has ghost touch which wasn’t happening before. So my next step is the new digitizer. Should I get the Front Panel Full Assembly or just the Front Panel Glass? Your website says the home button is not included but easy to switch out the new one. Are there instructions for that?
door
Voeg je antwoord toe
Danielle Misciagna zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 478
