Ga door naar hoofdinhoud
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
How to replace iPod classic backplate?
I want to replace the backplate on my iPod Classic to make it look better when I sell it. Isn't the hold switch and what looks like the battery glued down to the back plate? I know how to remove these things, but then how do I reattach them to my new backplate?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
You can get it here, and the step by step guide for installing it is here.
Replace a broken or damaged rear panel for the Thin iPod Classic with this part. This product does not include headphone jack or hold switch. Afbeelding
Product
iPod Classic Thin Rear Panel
$29.99
Was dit antwoord nuttig?
Score 1
1 Opmerking:
will, also make sure, that when you replace the rear panel, that you get the proper one for your model. Some of those do not interchange due to the "thicker "HDD. It is a straight forward task as long as you follow the links that rab777hp posted for you. Good Luck
door
Voeg je antwoord toe
will zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 3,833
