Ga door naar hoofdinhoud
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
220 Vragen Bekijk alle
iPad mini touch not working, Touch IC problem?
I have an iPad mini with minor water damage. It turns on, but touch is not working all. Tried a few different digitizers, same result, no touch. The digitizer FPC connector on motherboard is in perfect condition. No pin missing. No corrosions found. The FPC connector is just perfect.
We know iPhones all have touch IC and controller. But how about iPad mini? Does iPad mini have touch IC on motherboard as well? Where can I find it?
Any suggestions would be highly appreciated. Thanks.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
U1700 is the IC you are looking for
Was dit antwoord nuttig?
Score 2
4 opmerkingen:
Thanks for your quick answer. But U1300 is a tristar charging IC. Isn't it?
door
Many thanks for your revised answer. But no, it's not the one I am looking for. As I explained in my original post, I already tried a few new digitizer screens (all the screens I tried of cause come with the touch IC). As I said, all the screens I tried made no difference, no touch at all. So it's not the touch ic which comes with the screen that is faulty, it's the motherboard. But I don't know which IC on motherboard responsible for touch?
door
Hi Michael, many thanks in advance. :)
door
Do you have ZXW or schematic? the 820-3291-A is the actual Touch IC on the Flex.
and U1700 SLG5AP302 is the touch subsystem ic chip
Also
check for shorts on the row of caps at the FPC and the filters for continuity
and a few resistors that are not at the connector are (R1780) (R1750 - R1754)
C8238 (PP5V25_GRAPE)
I revised the answer with the IC you are looking for
door
Voeg je antwoord toe
phonestore.uk zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 3,783
