Ga door naar hoofdinhoud
Repair guides and support for your Mitsubishi TV, no longer produced by Mitsubishi Electric.
120 Vragen Bekijk alle
white dots covering the screen
I have the same problem with a wd-65734 is it the same fix and what is the part number
Is dit een goede vraag?
1 Opmerking
Richard Young your TV has white dots covering over 50% of the screen?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Richard Young what you have is a bad DMD chip in the light engine. Apparently this is a common issue with the Mitsu TV series. Only way to repair this, is by replacing the DMD board or the DLP chip. The replacement board for your TV is a Mitsubishi BK.80L88.21G (00.L8821G001) but the DLP chip is the same. it is a Mitsubishi 276P595010. It is available at places like this and others. Use this video to help you with the installation
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Richard Young zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 190
