Ga door naar hoofdinhoud
The Xiaomi Redmi Note 3 smartphone was released by Xiaomi in March 2016. It includes a non-removable 4050 mAh battery and supports up to 256 GB of removable storage.
34 Vragen Bekijk alle
Which charger wires should connect on the tip?
Hi I'm trying to fix my broken charger of Xiaomi Redmi 3s before a new one arrives. As you can see on the picture, there are four pins on the charger tip and four different colors of wires. Can anyone tell me which color of wire should go on which pin? Thank you.
Picture link :
https://imgur.com/a/SmqDk
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hi,
Here is the pin layout for USB ports
(click to enlarge for better viewing)
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thank you very much, I will try and report back.
door
Working perfectly. Thanks.
door
Voeg je antwoord toe
Negiku zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 160
