Gigabyte P34W-V3 Backlight Wont Turn On
Hi,
My Gigabyte P34w-V3 laptop will not power the back light, I have replaced the LCD screen (inverter board inbuilt) and the back light will still not turn on. If i press the hotkey to switch the screen on it flashes for a very short moment but remains off, if a light is shone on the screen the display can be seen.
The display also works via the HDMI out on an external monitor
Any ideas why my back-light won't remain on?
Thanks!
Is dit een goede vraag?
3 opmerkingen
Hi Adrian,
I am having the exact same problem as you with the same laptop, although I have not replaced the screen yet. If a screen replacement doesn't fix it, it must be a bad cable or connector. The back cover of my screen broke off from the bezel in the bottom right corner causing my screen to bend every time I open and close it. That could have caused my problem over time. Can you let me know if replacing the cable fixes yours?
door Mike
I have the same problem :(. How did you fix your laptop?
door Mike
Hello,
I have the same problem change display with new one, but still not working. When I press power button for a second backlight is on and then turn off.
Anyone have solution for this problem?
Thanks to everyone who helps.
door Julian Stanchev
