Ga door naar hoofdinhoud
The Dell Latitude E4200 is a portable device manufactured in 2008.
8 Vragen Bekijk alle
Where's the CMOS battery on Dell Latitude e4200?
The CMOS battery has given up on my E4200. How do I go about replacing it? Is it just one of the usual CR2032 button batteries?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
If you follow this guide to remove the keyboard the CMOS battery is located in the upper right corner of the machine. It looks like it has wires soldered to a connector thus requiring either a soldering job or a simple online purchase of a new one.
Dell Latitude E4200 Keyboard Replacement
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
Hi!
You can find a guide on how to replace the CMOS battery for this laptop in the service manual that I linked here, at page 14.
It is not a standard battery like on your PC, laptops have them wrapped up in some kind of plastic thingie and when replacing them you should replace them with one what's also in the same type of cover. You can see here what I'm talking about.
Score 2
Voeg je antwoord toe
Daleos zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 4,465
