Have Fusion Drive want to upgrade to SSD
Hello,
I have a 21.5" iMac 4K (2017) 1TB Fusion Drive and want to upgrade to a SSD.
Is it possible?
What I have to do?
Update (10/18/2017)
Oh! Crucial has a new SATA SSD which is very fast and CHEAP!
480 GB für 150€! It comes with an adapter.
Nice!
http://www.crucial.de/deu/de/imac-%2821*...
Update (25.10.2017)
Okay thank you guys! Now I understand.
$@$* happens ... I had bought an iMac with normal HDD and this can be changed easily... $@$* !
Fusion drive is almost the badest thing ....
Thank you!
Update (25.10.2017)
And 1TB Fusion Drive has 32 GB SSD and not 24 GB... ;-)
Apple says:
„Der 1 TB Fusion Drive kombiniert eine 1 TB Festplatte mit 32 GB schnellem SSD Speicher“
Is dit een goede vraag?
4 opmerkingen
Hold on here! The Crucial SSD is a 2.5" SSD. It's not a PCIe Blade SSD. You'll be giving up your current HD for the SSD.
Remember a Fusion Drive is the two physical drives within the system (SATA HDD & PCIe SSD) which then present themselves as one drive logically.
Apple uses a very small SSD in the 1TB Fusion Drive configs (24 GB) which is why it makes sense to replace it Vs the HDD.
door Dan
Huh?! It is 32 GB „SSD“ in a 1 TB FusionDrive but i think the FusionDrive is one Harddrive which I can change ?!
The new 2,5“ Crucial is very fast!!
Do you mean I cant change the HDD?
door Exitmode
The FusionDrive is too slow and not supported by APFS....
door Exitmode
No, its Logically 'One Drive' but is made up of two discreet physical drives using both the systems drive ports: HDD SATA port And the blade SSD port. Here's a good write-up: Wikipedia - Fusion Drive. I think you are thinking of a SSHD drive like: Seagate FireCuda SSHD which is a single drive with an onboard NAND flash used as a cache. That is not what Apple did here sorry.
Bottom line: You have no free ports to add-in still another drive.
Not saying the Crucial is a bad drive.
It's a matter of swapping out either the SATA HD for your Crucial SSD Or swapping out the Apple 24 GB blade SSD with a bigger Apple SSD.
Its up to you which way to go... I personally would want to hold on to my SATA HDD and put in a larger blade SSD.
But! As I said before your system is so new you'll loose the warranty opening it up so as a better solution I would go with the external USB3 or better a Thunderbolt SSD drive for now.
door Dan
