Replacement Charging Pins Badly Needed!
I need to replace the badly corroded charging pins on my Gear Fit 2.
It was a gift for pre-ordering the Samsung Galaxy Note 7 (That I still have), and I'm pretty sure that Sammy (Samsung) will not replace, or fix the device without me first returning my Note 7 (which I have no intention of doing so).
Is there somewhere (Amazon, Newegg, E-Bay) where I can purchase a replacement?
I'm an IT professional who has no problem tearing this thing apart and rebuilding it myself, but I just need to have the correct replacement parts on hand before doing so.
If anyone can provide me a Part Number, or the correct name of the circutboard that I'm replacing; that'd be most helpful.
Thank you in advance.
Is dit een goede vraag?
2 opmerkingen
That is not for the Gear Fit 2.
It looks like that part is for the original Gear Fit.
I was able to put a dab of solder (slightly smaller than a BB), but it only lasted a few weeks before falling off.
I also tried some wire glue (glue with carbon in it), but for some reason it had no effect whatsoever (device fails to charge).
Don't want to try soldering again as the last time I did so it caused a crater to form where the charging pin should go (due to melted plastic).
Not sure why the wire glue isn't working; I know that it is conductive as I have used it before several times in the past without issue when making minor repairs to circuitry.
Glad this thing was a free gift for pre-ordering the Note 7 (which I still have, and am currently using) as this thing was obviously designed with planned obsolesce in mind.
door EncryptedFile
motherAfucker product from SAMSUNG. ALL PEOPLES MONEY WASTE.
door birla
