Ga door naar hoofdinhoud
This LG Tribute smartphone is identified by model number LS660. The device was released in October of 2014 and runs on the Android operating system.
My phone wont turn back on
last night, i couldn't sleep so i was on my phone until'l it died after that i put it on the charger so it could charge while i sleep at first it was charging perfectly fine but when i woke up and picked it up it wouldn't turn on, and no it didn't overheat i tried pressing the power button down and the volume down at the same time but nothing, there was nothing wrong with my charger or my phone it wont turn on
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
@alexbelle14 this could be coincidental findings of a failed battery. It may have gotten discharged beyond it's threshold and just no longer holds a charge. Start with a new battery. This will also give you a known-good starting point should further troubleshooting become necessary.
Anything deeper than that will require you to disassemble your phone and check the charging port as well as the power circuit
Was dit antwoord nuttig?
Score 1
This happened to my LG TRIBUTE HD for Boost Mobile (9/17). No one could figure out why after buying new battery. Ended up buying another device. Same model. After a week of having new phone, I inserted new sim card on old device & it powered up. So put orig sim back in old device & it started right up and worked. The new sim still works in new device.
Could you please explain why that occurred? What did putting a new sim in old device do? I mean how did it start functioning again?
Voeg je antwoord toe
alexandria zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 1,976
