Ga door naar hoofdinhoud
De Elephone P6000 Pro werd uitgebracht in augustus 2015 en beschikt over 3 GB werkgeheugen en de Octa-Core MT6753-processor.
Is it possible to replace USB port?
My elephone p6000's USB port has been damaged to the point that has felt from the motherboard that it used to belong to. I have seen some sites that sell a USB port for this specific model, but I am wondering if it is possible to replace it for a new one for a regular user and, if so, which procedure should I follow, since AFAIK there's only a teardown guide explaining how to disassemble Elephone p6000, but does not mention anything specifically about USB port, other than it belongs to a secondary board (visit step 3: Elephone P6000 pro Demontage ).
Thanks in advance
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
It depends on what you mean by regular user.
The process is quite simple: you just unsolder the old port and then solder a new one. There are plenty of instructions. Just make sure that you follow the instructions.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thanks for your answer, George! Could you please tell me where are those instructions you are refering to? Although I am quite new to iFixit (just registered), AFAIK there's only a teardown guide explaining how to disassemble Elephone p6000, but does not mention anything specifically about USB port, other than it belongs to a secondary board (Elephone P6000 pro Demontage).
Since the USB has fallen apart from it, I was wondering if I can just simply plug a new one or I have to replace the secondary board.
door
Its possible but you'll have to find someone who can do it.
Voeg je antwoord toe
Carlos zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 30
Altijd: 1,144
