Ga door naar hoofdinhoud
Een grote vernieuwing van het Apple Pro Keyboard, uitgebracht in mei 2003. In 2005 bijgewerkt met USB 2.0.
Spacebar key not working
I got this A-1048 Keyboard of amazon and i used it for a while but now, I don't know what happened, but my spacebar key isn't working, anybody have any suggestions on how to repair a key that isn't working? Thanks
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
try blowing it on the side. The keyboard could have sand or dust that may stuck there.
or, use a thick paper and use it to clean the dust or sand.
good luck!
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Hi,
I recently bought an Apple A1048 keyboard, and has the same issue. I disassembled the keyboard, cleaned all parts and cleaned with a "contact cleaner" the membrane and still doesn't work.
Do you know what can is happened?
door
Very easy to clean out using this method. Also watch out for the long metal bracket under the spacebar coming free from its brackets. Can be reseated to stop the spacebar leaning too much left or right resulting in a no key press.
Voeg je antwoord toe
Anonymous Person zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 21
Altijd: 5,205
