Ga door naar hoofdinhoud
De BlackBerry Priv is de eerste smartphone van de Canadese fabrikant die draait op het Android-besturingssysteem en combineert veiligheid met goede prestaties.
hard reset? recovery mode?
i have a customer whos father passed away. she is trying to reset his blackberry to sell it as she cannot get into it. i cant seem to find a way to hard reset via button combo. help?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Afbeelding
I found this after seeing your question. I hope it helps. I posted the image because I had to jump through a hoop to see the answer.
Here is the website it comes from: Three ways to Hard reset Blackberry Priv.
Was dit antwoord nuttig?
2 opmerkingen:
I will try this when I get to work! Thank you! :)
door
Np! I hope it works!
door
Just log in 10 times with the wrong password or wrong pattern etc., then the phone will delete everything down to factory reset level, and restarts from scratch again.
1 Opmerking:
Actually that is incorrect, it will leave it stuck in a mode where you need the original google account to load past the setup screen... It has to be done via the actual factory reset option to avoid this...
door
Voeg je antwoord toe
Austin Harris zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 10
Altijd: 11,294
