Ga door naar hoofdinhoud
Released 2006, identified by model number E1705
10 Vragen Bekijk alle
cd/dvdram drive is not detected by windows xp or bios
Matshita DVD-R UJ-841S
Hello,
I have tried deleting the lower/upper filters and run Microsoft Fixit Cdrom with no luck. What else can I try that will fix my problem.
Thanks,
Lou
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Lou, not sure what computer you are using but I suppose it might be a Toshiba....anyhow lots and lots of folks out there with issues just like yours. Since the drive is not recognized in the BIOS, windows will also not recognize it. You might try to check in the BIOS if it (the drive) has been disabled. But my gut feeling here is that you may have to invest in a new drive,of course you do want to make sure that the drive is seated properly, that is gets power, and that all connections are nice and snug. Good Luck to you and let us know how it is going...
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thanks Oldturkey03. I will check out the drive. I am using a Dell Inspiron E1705 laptop.
door
Voeg je antwoord toe
Lou zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 8
Altijd: 1,771
