Ga door naar hoofdinhoud
A wide range of repair guides and support for the consumer-grade laptop computer line by Toshiba.
971 Vragen Bekijk alle
microphone is not working soundcard not found
Imy laptop came with skype built in mic and web cam my sister did something and now my mic does not work and when i go to devices it says no sound card located i know it worked befor because i have used it....please help
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
cece, your sister (:-) sure) may just have disabled it in Control Panel/Sound, this would just disable the driver in the Device Manager, but you should still see the disabled driver in Device Manager. It should have a red "X" on it in the Device Manager screen. Since it is disabled and not not removed, it will not show-up in a Hardware Scan.
Open the Device Manager and look in the category "Sound, Video and Game Controllers" and you should find the disabled driver (with a red "X") there. Right-click it and "enable". Also what Operating system do you have and what Satellite do you have? This will be important if my answer does not work for you. Hope this will work for you, good luck
Was dit antwoord nuttig?
Score 2
1 Opmerking:
+ Sound advice ;-)
door
Voeg je antwoord toe
cece zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 2,589
