Ga door naar hoofdinhoud
Model A1136 / 30, 60, or 80 GB hard drive / black or white plastic front
797 Vragen Bekijk alle
My hold switch is not unlocking
I have already taken it apart, with the manual, but cant figure out how to get it going...
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Losa, all you have to is to replace the switch when it is broken. There is really not a good way to fix it The part is inexpensive and easy to replace iPod Video 30 GB Headphone Jack & Hold Switch of course make sure that the ribbon cable is properly attached to the logic board. Good Luck.
iPod Video 30 GB Headphone Jack & Hold Switch Afbeelding
Product
$29.99
Was dit antwoord nuttig?
Score 2
In my case the problem on an 80G video turned out to be that the white plastic frame that keeps the hold switch external slider aligned to the actual internal switch was broken, so that the external slider lost alignment and contact with the internal switch and wasn't doing anything. There is no replacement part of the plastic frame.
1 Opmerking:
May be a cheap replacement back plate would resolve that. Some of those parts are hard to come by...
door
Voeg je antwoord toe
Losa zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 1,337
