Ga door naar hoofdinhoud
The Kenmore 110 Series is an easy to use home Washing machine created by Kenmore.
Does not complete final cycle.
Does not complete the last cycle. Says lid lock is on but the lid is not locked and you can open. You have to unplug the machine and the plug it in and set it to the last cycle to complete. after a while smells like something burning.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
@eficken it is a good indication that when it says the lid lock is on but it isn't that this is where your trouble is. I'd check it out first. Use a multimeter to see if it has power and continuity if closed. There may also be some wire damage since you say you've noticed some "smells like something burning."
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
eric zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 337
