Rear wobbly wheel, and rim and tyre A1
2001 Range Rover P38
Fast or slow speed, rear off side wheel wobbles ! Tyre place checked wheel and tyre, balanced it again to no avail. Refitted and still wobbles !
Is dit een goede vraag?
@robinvanboxel check the wheel bearing as well as the hub. Check to make sure that your half shaft assembly is not worn out or bend or has a worn bearing. You also want to check all the bushings of your Panhard rod and radius arms.
This document may help you to get started on thisRange-Rover-P38-Rear-Suspension.pdf
Was dit antwoord nuttig?
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 14
Altijd: 216
