Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
Battery Drain After Screen Replacement
I have recently had some issues after iPhone 6s screen replacement.
Whilst testing devices after screen replacement I have seen some rapid battery drain and in some cases full shutdowns.
There is nothing to suggest the devices weren't already like this (as we know the 6s battery situation) however I'm wondering can a screen casue this.
I have recently changed my screen supplier, it doesn't happen on each 6s but ive seen it 3-4times now in past few months and I am curious has anyone else experienced this.
Today turned device on after screen replacement and was 41%, this soon became 39% and whilst testing front camera it shut down. When powered up again it was at 10%
Thanks in advance
Is dit een goede vraag?
Score 10
3 opmerkingen
after screen replacement, battery goes dead fast when running apps
door
After screen replacement on my 6s the battery (a new one) lasts about 3 hours with NO use. It is not activated, does receive email, most everything else is turned off. The thing totally sucks
door
this is happening with my note 9 as well
door
Voeg een opmerking toe
6 Antwoorden
Gekozen oplossing
It's certainly possible, depending on the quality level of the screen. Even "premium" screens could do this but you wouldn't expect to see so many screens unless you got a really bad batch.
The easiest way to test is to replace the battery with a Power Supply and note the current draw and how it compares between good and bad screens. A poor quality backlight could draw excessive current. Also, are you eliminating the FCAM/Sensor as a variable?
Was dit antwoord nuttig?
Score 4
1 Opmerking:
What is the potential variable regarding FCAM/Sensor? I can't find anyone mentioning this elsewhere. If I would guess I'd say a faulty light sensor would "pulsate" the screenbrightness uncontrollably and thusly drain the battery?
door
Mostly this issue happens after replacing a fake lcd screen,becoz a fake lcd screen alwyz takes a lot of power jus to controll screen adjustment like backlight,slide motions and touch becoz its not meassured professioanally like the original one which came with the phone.the only option is to replace with original screen.you will see much differance on battery drainage..!!!
Score 1
Same here. Replaced with a fake screen on 6s. Using original one made no sense from investment POV (as it seemed then haha). Now I have it almost constantly connected to powerbank :)
Score 1
1 Opmerking:
I actually figured out the problem, for me at least, I had replaced the home button and it turned out to be a bad third party home button so I bought another one and it completely fixed the problem they have them on this website or on amazon hopefully this helped you.
door
Hi. I have same issue but I noticed that when i lifte the bottom of a screen of of the body the battery stays normal. Maybe isolation issues?
Have the same problem, thats how the battery drain with everything turnt to off to save battery (ex: localisation, background refresh, notifications, etc.)
Phone will drain from 100% to shut down in a short period without using it.
Solved for me: Someone in this thread suggested changing the home button. Mine in contrast to theirs was the original home button that I’d moved into a new third part screen. (It didn’t come with a button). The original button was Touch ID that stopped working.
So the battery would drain fast until eventually it was destroyed. (Too much charging and discharging).
The replacement button cost peanuts and I replaced the battery at the same time. Really pleased because I thought I might have to buy an original apple screen as people here have suggested. This worked for me anyway. Now I wake up and the battery is as charged as when I went to sleep. Bingo.
Voeg je antwoord toe
Niall zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 27
Afgelopen 30 dagen: 163
Altijd: 54,009
