Ga door naar hoofdinhoud
Een draagbare Bluetooth-speaker gefabriceerd door Ultimate Ears.
It will not charge?
Whenever I plug the power adapter into it and I charged it for over two nights and I go to turn it on it says critical battery please charge, then shuts off
Is dit een goede vraag?
Score 4
3 opmerkingen
Thanks. I will give it a try.
door
Do like i did, get mad, throw it at the couch, curse at it ,grab it then choke it, tell it sorry, plug it in and there it goes still not charging ,please help ,this thing isnt helping me with my anger management classes
door
May just need a new battery ;-}
door
Voeg een opmerking toe
6 Antwoorden
Filteren op:
Het nuttigste antwoord
Is the charging LED lit when you plug in the charger? It should be blinking. If not the USB port may need replacing.
Was dit antwoord nuttig?
Score 3
8 opmerkingen:
It rapidly blinks, unfortently
door
That sounds like a dead battery.
door
When you say dead battery, does that mean it will no longer accept a charge?
Mine was sitting in the closet for months and I charged it overnight, light was blinking, it says it's charging when I try to turn it on but he no charge the next morning.
door
Courtney, Yes if the White LED just above the USB port is blinking. If the LED is not lighting up then the charger, cable or the USB port its self have failed so the unit is unable to be charged. If the LED is blinking and never gets to a steady state then the battery has failed (this is when the onboard voice will tell you: "critical battery please charge" and the On/Off LED will be Red.
door
Mine just says"recharge battery" but won't take a charge. I play it often. I leave the charger in when I'm playing but it still looses it"s power.
door
3 commentaren meer tonen
Purchased one 2 days ago that was on 28/12 /2017...needed recharging the next day.. charged it overnight, next morning saying battery critical again! So problem solve with YES you guessed it utube.. watched several & after doing everything but put it in the fridge like one guy suggested
Score 1
The charging led on mine only flashes when the battery is removed.
Speaker works normally with no battery fitted, but does not switch on with battery in.
Shows 40% charge with or without battery.
1 Opmerking:
does it mean you have to replace the battery?
door
Unplug the charger and put it back in then wait 40 min then test it
The issue I have with mine is I believe a USB port issue. I have to fight it in a specific angle/way to start charging. It's not plug & charge for me. When I do get the charge indicator to appear, 24 hours later the speaker turns on but then critical battery please charge then off.
I think the charge port is the issue for me.
It's too weak to let me play music from it to see speaker quality.
1 Opmerking:
Check this guide out Logitech UE MegaBoom: Vervanging van de AUX-poort en micro-USB-poortmodule You will likely need to find a replacement port from a junker or see if you can still find a spare.
door
My UE MEGABOOM only was playing while charging. When I displuged, it stopped playing (but da light of the on/off button was still on and my phone was still reconizing it on the bluetooh).
I did the following steps said by Andrew Pifferini  on the link below:
Why won't my speaker turn on?
Now is playing without the charging cables.
Hope this helps;
Voeg je antwoord toe
Ryan Morazes zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 31
Altijd: 41,818
