Ga door naar hoofdinhoud
Repair guides and troubleshooting for HP Pavilion laptops that have model numbers beginning with 15-z.
Why does the screen boot so slow
So today when I boot up the laptop, it went into the login screen, and I got in. Once I got in it's a black screen. I press ctrl+alt+delete to get into task manager. I'm still able to run my games on steam. And after like 5 minutes the screen comes up. So I want to ask why does it take so long to load to the screen
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Steven Long long startups are usually related to bad caps but you want to make sure that there is nothing else going on. Connect an external monitor and see how quickly that will display. If it does then you have to disassemble your computer and check your motherboard which can be a chore since you will have to find the schematic for it.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
I don't think it has anything to do with bad caps because I can still go into task manager and run the steam games
door
This "after like 5 minutes the screen comes up. " can be caused by bad caps.....did you try an external monitor?
door
I would check the SMART status of the hard drive. If it has bad sectors, it could take a long time to boot into Windows, making you think there's a fault with the screen. An easy program to check the SMART status is Crystal Disk Info. If it's anything other than blue, I consider replacing the drive and installing the OS. If you have a linux boot disk, the disk utility in Ubuntu or Mint will tell you if you have any bad sectors and you'll see if it goes through POST and boots into the OS in a faster manner.
I have seen this problem, the screen is black and you can open Task Manager to do some things. This is a profile issue, try signing in as administrator. If you don't know the password, you can use Task Manager to open Computer Management, click on Local Users and Groups, then click on Users and right click on the administrator account and choose set password, set the password. Log out and then try signing in as Other User, use the administrator account and password. If the administrator account works correctly, try renaming your account so that the OS is forced to create a new account for you. If that all works then you can transfer your data (desktop, Favorites, Downloads, Documents) to the new account. Be sure to make the new account an administrator. Good luck.
2 opmerkingen:
Nope. Still the same problem
door
Then if this did not work the next thing is to back up data and reinstall the operating system.
door
Voeg je antwoord toe
Steven Long zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 243
