Why when I answer my Bluetooth the call goes to speaker phone
When i get a phone call, I answer with my voyager edge, but the call goes to my phones speaker and not thru my bluetooth
Is dit een goede vraag?
You can install the Plantronics app "PLT Hub". That shows whether the headset has recognised that it's in your ear or not. If not, the call goes to the phone's speaker.
Sometimes it helps to place the headset on a non-metallic surface with the earpod point up while charging. This should re-calibrate the sensors.
HTH
Was dit antwoord nuttig?
Check the properties of the Bluetooth connection on your phone
Settings, Bluetooth, Connected Device settings.
There should be several check boxes related to functions that the connection can be used for. (Media audio, Phone audio, etc.)
I turned off the sensor and that did the trick for me.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 19
Altijd: 2,416
