Ga door naar hoofdinhoud
Repair guides and support for smaller headsets that rest on top of the ear, also known as supra-aural headphones.
60 Vragen Bekijk alle
I have IFrogz headphones
Brought them in Hawaii months ago , worked great , but all of a sudden they won't charge , and the charger hole keeps getting pushed into the headphones , so to charge I used to pull the ear muffs off to get better access , don't know if there just cheap or I'm doing something wrong ??
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
@eth110697 I do not think you are doing anything wrong. It sounds more like the charging port is most likely loose and moves higher up. To check on that you will most likely have to disassemble those. Let us know what exact model this is.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Ethan schloeffel zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 185
