Ga door naar hoofdinhoud
1.4GHz or 1.6GHz Processor / 64GB or 128GB SSD
162 Vragen Bekijk alle
Mac Air late 2010 does not turn on
Power Adaptor is connected, charging is normal (orange light is lighted on the adaptor connector).
No signs of life and no welcome chime after I press Power button, except for the cooling fan turning on after a minute.
PRAM reset (Command-Option_P-R keys pressed) and SMC reset (Shift-Option-Command-Power on buttons depressed then released) have not helped.
Any other ideas, guys?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Review this Apple T/N: Apple Portables: Troubleshooting MagSafe adapters
An Orange MagSafe LED that never turns Green often implies the battery is not charging. It also can be a bad battery as well.
Was dit antwoord nuttig?
Score 1
4 opmerkingen:
Orange light turned green after 2 hours. So it's a good battery and charger.
door
Can you give us some background here on what this system has encountered. Like did it get a bang or get wet as some point? Was the system running and then shut it's self off?
door
I last used the laptop 2 weeks ago and kept it in the storage drawer.. Now, it is kaput. No one touched it for the duration it was stored.
door
Dead systems on the most part need one to test for voltagages from the battery to the different power rails on the logic board.
You'll need access to the schematics, can read them, as well as have the needed tools to probe the logic board. For most, this is beyond a DIY job. Sorry :-{
door
Voeg je antwoord toe
Bernie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 6
Altijd: 820
